I have an 84 BII with a 2.8L. It takes a few minutes of revving the engine before it will idle and not cut out.
I have replaced the fuel and air filters, the pcv rattles fine and it has the right amount of oil.
background info -
the vacuum coffee can is gone but the line is connected to the spot it would go after going into the can.
The carb will drip a drop of gas when releasing the thottle from a full pump, probably needs a rebuild.
Since it runs fine after it has been warmed up, I'm not suspecting the carb. What could cause this?
						cold blooded
is your choke adjusted right?
most carbs run cold natured but if tuned right it can be put to a minimum. have you tryed to tune the carb...ie check the float, adjust the needles?
