Explorer TTB
Explorer TTB
My son and I bought a 3.73 posi 8.8 from an Explorer today at our local
Pull-a-Part for $86.00 !
The Explorer 8.8 is about 3" wider than the B2s 7.5. We thought about cutting the housing down and using the B2 axles or maybe even welding nine inch style ends on the 8.8 and eliminate the C-clips all together. Now we are thinking gaining 1-1/2" per side will be ok if I can get the front with to match.
I am wondering if the front TTB from the Explorer will bolt
up under the B2 ?
up under the B2 ?
Hello Tek. So the Explorer mounting holes to spring pocket dimensions
in the front are the same from B2 to Explorer ?
What did you mean about the drive line ?
I grabbed the rear drive line when we bought the 8.8 they only charged
$12.00 for it.
I will have to make some changes to the spring, shock and sway bar mounts on the 8.8 its a completely different lashup.
Thanks
$12.00 for it.
Thanks
You have a T18 mated to a 1356 in your Bronco ? Is the 1356 strong enough to handle V8 torque ? Hmmm, I am just learning what transmissions and transfercases will work together. At least which combosno v8? why drive? wrote:You can pull a factory l/s carrier from a XJ rear d35 and use it in your front d35. Thats usually the cheapest way to get it.
make sense.
1356 came stock behind T18's in the late 80's. You can bolt any 31 spline 6 bolt full size transfer case up to a T18/T19/Np435/M5ODR2/ZF, etc. 1356s came behind 7.5s and PSD's so they can more than handle a puny 5.0. They are a reeeally tight fit in a ranger/b2 though. A np208 or np205 would be a better way to go if you care about fitment.
94 4x4 Navajo 8" lift
Ok, I was confused, I was thinking the 1356 was the B2 transfercase.no v8? why drive? wrote:1356 came stock behind T18's in the late 80's. You can bolt any 31 spline 6 bolt full size transfer case up to a T18/T19/Np435/M5ODR2/ZF, etc. 1356s came behind 7.5s and PSD's so they can more than handle a puny 5.0. They are a reeeally tight fit in a ranger/b2 though. A np208 or np205 would be a better way to go if you care about fitment.
I owned a 1982 full size Bronco in the late 80s it had a C6, and aluminum transfer case. I think it was a 208 ? Did that same transfer case bolt up to a 435NP ?
The reason I ask is, there are several junker full sized Broncos around this area. I think I could probably get a decent deal on one of them and my son wants to use a 435NP we already have.
yes
