Anyhow, I want to use my bII out in the super soft beach sand. The stock 205x75-15 on 5.5" rims are going. I got four 15x 7 early '90's Explorer rims that came with 235x75's on them. I want to fit 265x75's... very close to 31x10.5's but only 4 plies... so mayby they might "squat" wider when deflated to 15-20 psi. Opinions please.
Thinking I need a min. of 3" of lift, I could buy a body lift kit but fabbing up 10 body spacers using stainless pipe capped off at both ends would be so easy at work, but I can only guess what else's is in the kit.
What size are the ten new body spacer bolts... any guesses? .... 3/8" or 1/2" dia.? 7" long enough?( Yeah, I know their 3" longer than stock.
The steering shaft extension they sell would be the toughest to duplicate.. Does it attach at the top flex joint or bottom, (at the steering box)? How much does it add to the length of the stock bII shaft? Anyone care to take a photo of theirs?
Also, what else would I need ? (The bumper brackets don't come with the kit I saw at Perf. Acces. , so likely I'd be making them anyhow).
Is the radiator lowered with brackets and if so, what do they look like? Just flat plates?
Kit info indicates the automatic tranny linkage won't need any alterations.
What else? Gastank hose? Heater hoses? Any "now too short" wire issues? Am I forgetting anything? Oh yeah, the emerg brake cable.... I can fix whatevers screwed-up there.
Hey, I know I'm asking a lot of specific questions so thanks for your opinions !! Dave.
