clutch bleeding
clutch bleeding
I found out yesterday that my clutch slave is broken (leaking fluid when pedal is depressed) I was wondering if anyone would explain in depth how to bleed the clutch system on the external clutch (84 year). The haynes book i have says you have to buy a prebled system from ford because it cannot be bled in service. I cant believe that it just doesnt make much sense. Thanks
"Dont call him a cowboy until you've seen him ride"
mccutcheon4
