What fuel pump would I use to run on my BII with my fuel cell? The cell I have already has a GM style sender in it, and I know the BII has two fuel pumps. Would a basic high pressure pump work, I know some of them are like 125 psi MAX, and your fuel regulator should regulate the flow. Anyone know?
I work at Auto Zone so a part # would be great.
						Fuel Cell ?
I know the stock frame mounted pump is a good one. It works with V8's. The stock in-tank pump is just a low pressure feeder pump, and isn't really required, especially since your fuel cell is probably mounted in the bed. I think in 1990 they went to a single in-tank pump though.
What engine are you running?
so you are just using a stock motor and moving your fuel cell up into the back?
if that is the case just use a factory setup and run some new line up to the fuel cell. if you need a feeder just go get a cheap carb electric pump and run it as a feeder.
