Hmmmm???
Hmmmm???
I got dial up for a little while until my DSL gets reconnected (errrr wife
). So I got on for my abuse for over the weekend. Did you guys make it out OK? I waited on the corner for about 4 hours and became a winching point for 4-5 heeps. I didn't even have to sit inside on the brakes cause my hog is so heavy. I thinkin' about a spool now for the rear cause the rear locker kept failing. I do that after I fix the sqeakin' front u-joint.
Yep, we made it out ok. Sorry we got separated. That wasn't really the plan. Everything turned into a cluster and my CB wasn't working, so I didn't have a clue what was going on.
I'll go easy on ya, but you need to get your FORD going so you can keep up
At least you don't drive a jeep....it was like a WalMart parking lot with all the jeeps stuck everywhere.
I haven't had time to put up pics yet. I did get a good one of your tank though.
That picture does my rig to much justice since you guys climbed over the snow bank I was plowing into. And it isn't your fault that my U-joint took a crap on the trail.
I had a good time and I know the mission is to get to the top.Good job you guys. I have no hard feelings cause I hae been on a few trips where I have had to drag people out cause they kept running on failing equipment. I just swanted to get out on mine without being a burden to anyone else and my goal was acheived. I do think that the tank needs 38's though to get some floatation. And I still think the Timber Tambers need some help.
P.S. The tank will get a big block this month and the it is time for the F F F ford.
Ya It aparently dried up on the trip. When I dropped my air down to 5 psi it was enough load to make it squeal with agony. I still need a rig to haul kids in though so selling it is not a necessity. I can't afford replacing glass in a BII. Ypu know how that goes.
Hey where's the pict of the BII rubbing the pole???
I bought the U-joint yesterday and I will fix it tomorrow for a trip that I am planning to take on Sunday. I just hope there is enough parking in the boat launch since there is a flood watch.
My buddy with the Samuri Is bringing chains and Screwin studs from the Ice Races to make up for the unforgiving bias swampers.
P.S. I just got a HUGE R.V. cam for the B.B. I might need it for towing purposes
