Electric FWD shift problem question.
Al
Post by Al »
I had a problem with my mid 80's Bronco II shifting slow into FWD. I've heard this is not uncommon.
Now I have the transfer case out of my '90 while putting in a new clutch. Is there any preventive maintenance I can do while its out to prevent this problem from happening? Lube some linkage or do something with the elec. motor? Don't know if it has been a problem with this particular one, I bought it with the clutch out, never have driven it.
Thanks, Al.
The easiest way to make sure it will work, is to swap out your electric and out in a manual.
