79 bronco
BIG Z DUDE
79 bronco
I have a chance to get a 79 bronco. I have a 84 bronco II 4x4 2.8 5 speed and want to put the drive train in it. one prblem is the 79 has a 400 with an auto trans. will the 400 fit or shuld I trade it for a 302. allso is there a 5 speed for a 302 or 400?
Dbrown and Fatman both put a bronco II body on a fullsize bronco frame. I don't think they were happy though, as they both moved on to new rigs.
The 400ci isn't going to fit in the BII....I'm sure you can make it work, but I don't think it would be that practical. I would definately trade for 302, or even a 351W.
The auto trans won't bolt up to the small blocks either. You might want to hang on to the NP205 transfercase though....if that's what it has.
Ford did use a couple 5 speeds. The ZF-5 is pretty popular. Haven't heard of one in a BII yet though.
There's also a T-5, but the gearing sucks, and they really aren't that strong. The transfercase adapter will kill you too.
You can swap in the axles. I prefer to narrow them, but quite a few guys run them full width.
BIG Z DUDE
I was happy with how my swap came out but it just didn't meet my long term goals.......packing a baby around in a chop top rig just isn't that safe. that and I had an oppertunity to jump on a Early Bronco.
fitting the 400 in a BII frame will be hard. if you post it over on www.fullsizebronco.com you might get it sold along with that tranny. I agree that you should probably go with a 302 or 351W. the NP435 is the most popular swap for a manual tranny because of the low first gear but this tranny doesn't have overdrive. I plan to go with a 302/NP435/205 for my next trail truck. my next truck will also keep its top.
