Spark plugs
Spark plugs
Any tips or tricks for changing out the plugs in an 86 2.9? Looks like reacjing all of them's going to be a bit of a bear.
Jan Trask
They aren't too bad to get out/in. I use a swivel head 3/8 ratchet and only use the ratchet to loosen the plug. Then turn the plug out and back in by hand with an extension on the socket. be sure not to overtighten when installing and using an anti seaze on the treads helps to keep them easier to remove the next time.
