do i need an i-beam drop bracket??
turphy
Post by turphy »
I have a 1988 bII and will soon be adding a 2.5 inch suspension lift(spacers in front blocks in rear). Will this screw my toe-in up enough to warrent getting the i-beam drop bracket, or is it not needed? Also, if it is needed, is there another solution to getting the correct toe-in??
Thanks
-Tim
redneckwelder
Post by redneckwelder »
yes you will need the drop brackets if you dont the front will vw and the front shaft wont fit it will hit the trans cross member if you got $550 check ebay for a complete 4 lift w shocks ( search bronco ii lift )
