Need some help with DS conversion
				vicsbronco
Hello, guys!
After weeks of unsuccesfull no-start (see my 84 B2 won't start)I started DS conversion. Couple questions:
I have an AC and one of the wires from it runs to the main wire harness that's laying on the passenger fender now. Do I just disconnect it?
I think I cut wires from oil sender unit along with others. Where is this unit located and where do I splice them too?
Vaccum lines from smog pump- remove and plug them? PCV valve- just lay that hose behind the engine and plug it?
I'm cross posting with other site to get more info- need to get it done tonight- it will be snowing again.
Thanks a lot.
Thanks a lot.
There was no need to cut any wires. The computer harness is separate from the guages/ac/lights etc. I just pulled the harness apart and separated the wires.
All the computer wires will work their way back to the computer on the passenger side kick panel.
The guages all go to the square plug on the drivers side firewall. The duraspark module should plug into the the round plug on the drivers side firewall. In some cases it's necessary to swap a couple duraspark wires, but try it first.
All the vacuum lines can be removed as well as the smog pump. You can cut the crossover tube on the exhaust manifold and pinch it off and fold it over.
The PCV stuff must stay.
				vicsbronco
				vicsbronco
It's only one wire going to the OP sending unit. On my bronco it's white with a red line. You should get yourself a chilton manual, they have schematics with wire colors.vicsbronco wrote:Thanks!
I assume wires from it going to the square plug, just need to figure out which to which.
Which harness are you talking about? From the duraspark module to the distributor? If so, then I'd recommend getting an OEM harness. You can get by using standard spade connectors, but that's hack.vicsbronco wrote: Connectors on the DS ignition are round ones. What is the best way to connect wires to it? ( I don't have a OEM harness)
The duraspark module should plug right in to your BII harness.
				vicsbronco
Thanks for all your help!.
DS conversion finished, you can kill an elaphant with that spark, but... no start. Plugs are dry. Fuel pump? But why it doesn't even catch with starting fluid? Now gas tank started leaking again.
What a luck! Bought this truck, invested almost $500 with no results.
Having a hard time to decide what to do- sell for parts or keep going.
if you are getting spark to the plugs then it almost has to be a fuel problem. since you sprayed starter fluid in to try to start I would say you might have to dig deeper.
one thing before you go on though, did you try to fill the boul with gas and start?
did you go get a manual?
if you are 100% positive you are getting spark, and 100% fuel is in there I would go to adjusting the valves. on the 2.8L you have to do this everyonce in a while. also that motor will chatter a little just because it is a solid lift cam. so if it chatters a little it's ok. this is the reason I hated my 2.8L in my old 84.
remember when you adjust the valves......do it right. if done wrong it can bend pushrods, grind down cams and destroy lifters if you get them to tight. follow the instructions in the manual 100% do not try to take short cuts.
When you installed the duraspark dizzy, did you find TDC on the #1 cylinder? Sure you were on the compression stroke. I got a hunch you are probably 180* out.vicsbronco wrote:Thanks for all your help!.
You know the engine runs, so you know you have compression. You say you have good spark, and you've given it a shot of starting fluid.....that pretty much only leaves ignition timing. There's a small chance that it's something with the ignition switch. Also if you wired the durspark module wrong, it's going to throw your timing off, possibly enough that it won't start.
				vicsbronco
Ignition switch is new. I have a Hayness manual, but don't know where else to look.
Compression is 120 on all 6 cylinders, I took fuel line off, crank the engine, fuel is going , so pump is working. I didn't double check on 180 degree stuff, but during distributor installation I found DTC on #1 and made sure rotor was pointing to plug #1- it's kinda 10-15 degrees to the left if you looking from the front of the engine.
About valves- that might be a problem or maybe timing gears? When I bought it, engine was running okay and I hate to touch the valves for now.
As for timing gears- with valve cover off and distributor cap off I see rotor spinning and valves moving. Does that mean gears are okay?
				vicsbronco
				vicsbronco
Cyl. #1 is first on the left (looking towards windshield).
My rotor was pointing at #3 when I was installing distributor. Dumb head!
I used ratchet to turn the main pulley, removed spark plug at #1 and used a long screwdriver to catch TDC.
If this will work out, from what years and models I can use a gas tank?
New one is $100.
New one is $100.
Well hopefully you got it.vicsbronco wrote:Cyl. #1 is first on the left (looking towards windshield).
New one is $100.
Still, you need to be at TDC of the compression stroke.
Since you are carbed, you need a tank from 84-85
