broncoo's B2 rollin again
marinebroncoii
Post by marinebroncoii »
doubler fits nice, D-shaft angle won't be SOO bad. Who needs a radiator support when you can use your radiator for support right? I just hop you put something in front, behind, or on top of your radiator to support the front end, but I think it will get plenty of flow with no obstructions.
broncoo
Post by broncoo »
rear shaft angle will only be about 10-15*
and as for the support i'm not gonna flange mount the rad they always end up cracking the tanks gonna saddle mount it instead
but i fab stainless and alum for a living and what i have planned will work well
broncoo
Post by broncoo »
some more progress got the engine runnin sounds good also finished mounting my rad and taurus fan the intake hose that goes thru the firewall collapses at about 4000rpm so i will have to make something stiffer or put a larger mass air sensor on it
broncoo
Post by broncoo »
almost ready to go 4:1 rocks too idles wherever you point it
Nice fan shroud! I think that's exactly what I need to do.
Your radius arm brackets look good too. Lot's of clearance. I look forward to seeing some wheelin pics.
broncoo
Post by broncoo »
thanks man i look forward to wheelin it
