lower rad hose
lower rad hose
for those of you that did the 5.0L swap what did you use for a lower rad hose? i don't really want any unions in my hose but am havin trouble finding one that will fit
btw i only have 2.25" from the edge of my rad outlet to the pully on my swapped in saginaw pump
anyone ever use this stuff?
http://www.coolflex.com/cfm/welcome.cfm
I had to splice 2 hoses together. I really really didn't want to do it at the time, but I was sick of looking for something that would work.
Now 4years later, and a hell of a lot of wheelin and daily driving, I wouldn't think twice about it. It's been working great. In fact I need to do a radiator flush.
At the time, I think I tried some flex hose. It worked to get from point A to point B, but it wouldn't hold shape to clear the power steering belt. The stuff in the link might work a little better.
I had a problem on a previous setup and I took a 1 3/4 x .120 wall bend and cut the inside, bent it more and welded it up to make it tighter. Then I used a small chunk of hose from the rad to the tube back to hose to the water pump. I also welded a bracket off of the tube to hold it in place because it was only about 1/4" away. Worked well for a few years till the entire thing was swapped out.
HTH
HTH
I used something from the plumbing section...I think it was a threaded piece of galvanized tube. I figured the threads would help it seal. It's been perfect. Not sure how it's holding up corrosion wise, but I expect it's fine.
The hose from the water pump is from a 77 granada (my engine donor). It almost worked, but the radiator outlet was the the wrong size, I think 1.75". I believe it's 1.5" off the waterpump. I think 5.0L are 1.75 off the waterpump. I main reason I had to splice was to get the right size on the hose. I don't recall what hose I used for that. I'll try and dig it up. Does your outlet come off the radiator at a 45*?
I've asked my dad to take some pics of mine, it was even close to the pulley but I got it to work without joining two together. I don't even remember how now but I know I did buy like 5 or 6 hoses to take home and try that I thought might work and one of them did. I just went behind the counter at autozone and looked through all their hoses. I'll post pics when/if I get them.
I did put a bead on it to help keep the hose on. I also coated it with something to keep it from rusting, but I don't recall what it was, it was fine when removed after about three years.
The brackets are fairly common at pull a part, I had one that I butchered
for my setup before I realized it would not work. You would still have to adapt the York to the bracket but it's a piece of cake.
