do the gear ratios have to be the same or different?
For front and rear I mean? does the transfer case feed the two out and a 1 to one ratio or does the front spin slower or faster? Just wondering, I have 5.13 in the rear right now and I was just going to do 5.13 in the front to but I an wondering which gear ratio would be correct. would 5.13 work or would it have to be higher or lower or what? itss an 87 bronco running a d44 in the front and a ford 9" in the back, has the stock 2.9. and I am hoping to run 38"s. if any of that matters. if you guys could help me that would be great. sure I could check it myself, but I figure one of you guys knows it already so it would be easyer to just ask you guys.
yes, the front and back has to match. I have heard of people running 3.50's and 3.55's with no problems but I wouldn't push it if you don't have to. a 5.13 is probably about right for 38's.
Happy_Jack
The only reason to run different ratio ring and pinions is if you were going with two different tire sizes. Some mud bogger's did this at one time on rigs that only ran in competition. Seem to remember they would run the front a little faster. For some reason certian axle combinations will be off slightly. Like 4.09 in one end and 4.11 in the other. Like DBrown said this is acceptable but try to stay as close as you can get if you are running the same size tire front and back.
The mud boggers wanted their fronts to spin a little faster so their steering would be more responsive. That's my understanding anyway.
I think up to a 2% difference is acceptable. I bet the difference between a new and used tire is more than that. Heck new tires probably vary that much.
But as others have said, you want matching ratios otherwise your transfer case will probably explode.
