BroncoII tach's
dave-stjohn
BroncoII tach's
I have a 86 B2 and the tach doesn't work, the needle was broken off so I went ahead and got a new one from the boneyard and it doesn't work either, the gauges all connect to that instrument motherboard so I haven't been able to find a wire to see if one is broken, does anyone know how to find this out?
there is a green wire that goes from the coil to the harness on the firewall on the driverside. trace that wire it controls the tach. wireing problems can be frustrating.....don't get upset if it takes you a little time to find the diconnection.
dave-stjohn
tach wire
thanks for the info, I'll give this a shot and see how it works.
Trigger_2001
a volt meter works better then a comb
