rattling/thumping noise
I have a 1990 Bronco II with a 5 speed manual transmission. Just last week I started hearing a rattling noise. It goes away when I press the clutch pedal down. It was present when in all gears and when it is in neutral. I had assumed it was the throw-out bearing. Just this weekend I replaced the clutch, pressure plate, pilot bearing, and throw-out bearing. I am still hearing the rattling. I am confused about this.
did you check the play in the input shaft when you had the tranny out?
I never repaired one of those but I would assume that you will need special tools. I would take it to a tranny shop or replace the tranny. the rebuild bill on these things is usually more the the price of replacement. some poeple can do the 302 swap for the price of the tranny rebuild.......
