fabrication on frame
hello this is vvp.  I am putting a ranger cab onto a bronco2 frame.my question is what is the trick for the rear cab mounts. does anyone have photos of this process and or and helpful advice? thanks for your time. vvp
Re: fabrication on frame
I have seen a thread here a long time ago about someone doing what you are asking about. I remember the rear mount was something built up on each frame rail with a cross member going across the right under the back of the cab.
You might want to do a search here on that subject.
