oil pressure switch removal on 1987 2.9 ltr. bronco 2
droblowin420
do you have to remove the motor mount to remove the oil pressure switch, or getting the oil pressure switch socket would fit in between the mount and oil pressure switch?
Re: oil pressure switch removal on 1987 2.9 ltr. bronco 2
I have done it with a swt. socket but it's tight. Might have to go at it off center. Good luck.
