Breaking Front Half Shafts
I keep twisting of factory front half shafts. What is the best way to beef up the front drive?
Re: Breaking Front Half Shafts
cooner wrote:I keep twisting of factory front half shafts. What is the best way to beef up the front drive?
Well if ya running Dana 28 then that is to be expected.
From an 91 thru 94 Exploder or of course there are a bunch of SAS ways to go.
Thanks tekatlarge! It is frustrating to keep replacing half shafts. I am just running the factory 2.9L engine but it cranks some torque and will go more places than all my buddies full size trucks etc. I was curious what would be a good swap. There are a lot of good explorer junkers in my area. Sure I can find a replacement.
The explorer swap is the most common. it will increase the track width by I think it is 3 inches total. This may lead to some tire rub depending on your fenders. If you use the rig on the streets be sure you have the flared fender type setup or the cops will try to write you up for exposed tires outside the vehicle or no mud flaps.
The other swaps are straight axle types and are not just a swap installation.
