bronco springs
Mason205
bronco springs
Post by Mason205 »
can you put original bronco springs on a bronco 2 or maybe leafs or something?
Re: bronco springs
The rear Early Bronco springs are quite a bit shorter than stock Bronco II.
Re: bronco springs
Coil springs will work from the EB.
Re: bronco springs
Phillippi wrote:Coil springs will work from the EB.
they do??
wiggle_wagon
Re: bronco springs
Post by wiggle_wagon »
They are shorter in stock form and a little larger diameter but can be easily adapted to fit. Many who swap the early bronco axle also use the EB (lifted) coil springs.
