suspension swap?
suspension swap?
is the independent suspension swap of a 1992 ford explorer 4x4 and a 1990 broncoII 4x4 a direct swap? or is there a problem area???
Re: suspension swap?
If I remember correctly, it is a direct swap.
wiggle_wagon
Its a direct swap. Bronco II's built between November 1989 and February 1990 have the Dana 35 ttb (as in the Explorer) from the factory.
Even the 2wd Bronco II can use this front suspension.
