1.Grinding popping noise during take off or acceleration,sound like it coming from the back or center of vehicle??
2.4wd will engage with button but will not disengage,unless you disconnect the battery wait awhile then hit the button??
3.Door lock work fine with button in cab,but will not unlock with key,barley turns then comes to a dead stop.
4.Fuel gauge only reads E or F....sending unit??
Any help with issues would be grate new to the bronco II world...one last question what is the widest tire and wheel combo for stock height.I want wider tires to help stabilize the truck and reduce roll over risk!!
