alright guys i got my bronco 2 a few months ago and found that there was a problem wid da fuel system so i
1.checked the relays
2cleaned both fuel filters
3.took out the tank and cleaned it up
4.fixed and cleaned the lp pump
5.bled the fuel lines
6.fixed some broken wires
and today when i went to put it in it wouldnt start and again there was no fuel in any of the lines so i took the tank back out and im testing the lp pump wich seems to work fine.....but only out of the car
.........today i unhooked the clip that went to the inertai switch and then rehooked it and 4 sum reason now none of my pumps r priming or even getting power
all i can hear wen i turn the key is the ?relays? turning on and of wich sounds like a litttle click .......so i no both my fuel pump work but what can i do 2 fix this inertia switch bs
