89 b2 wit a 302 question
---muddigger---
yo i got a 89 wit a 302 in it
runs strong as hell n is pushin 400hp beleive it or not
but when i go to shut it off i turn the key to off n it still wants to run. it kinda putters llike its gunna conk then it shuts off. any tips?
thx
Re: 89 b2 wit a 302 question
retard the timming a little,or turn the idle down. whats the specs on the motor
beat me to it Dave
---muddigger---
well i jus got the beast. its a 4 barrel bored out 302 with: 650 eb carb, long tube headers, no cats, flomaster dual 40s, dual pushers, aod trans, the entire engine is rebuilt with aftermarket cams, pistons, rods , n manifold. theres even more stuff done to it that im forgetin. anyway its lifted 7" w/33 but im goin t0 35s
Try running some high octane gas. If it's a built engine, then it might have a high compression ratio, causing it to detonate once the ignition is turned off.
---muddigger---
yeah i gotta try it n im gunna adjust the carb too thx
you should try retarding the timing because if its to far advanced it will cause excess heat in the cylinder thus allowing the gas to detonate with out spark. A couple degrees will make a difference.
justinC wrote:you should try retarding the timing because if its to far advanced it will cause excess heat in the cylinder thus allowing the gas to detonate with out spark. A couple degrees will make a difference.
Ranger Dave wrote:retard the timming a little,or turn the idle down.
didnt i say that
---muddigger---
yeah thx guys. problem solved. good as new
---muddigger--- wrote:yeah thx guys. problem solved. good as new
soooo,you gonna tell us or want, we told you what to try
---muddigger---
the throttle was stickin a lil so i made a braket n put a spring on it to make a throttle return n its perfect now
