np435
You're almost there now....
basically all I did was put the tranny in first and bend the shifter along the same contour of the dash. Then midway up the dash, it breaks away just a tad.
Is the 2nd gen dash a lot different? I forgot what is looks like in that area.
how did y'all bend your shifters? BFH? :redneck:
wilber
Post by wilber »
DBrown wrote:how did y'all bend your shifters? BFH? :redneck:
torch :D
Yep, heat her up red hot and it bends pretty easy.
wilber
Post by wilber »
got it bent up, works alot better, now the problem is , its in gear when the shifter is in neutral, so out comes the shifter again. do you have a pic of the tranny in neutral so i can make sure all my gears are the right way for the shift forks
wilber
Post by wilber »
figured it out, pulled it out of the garage, felt so great...
fawker realy moves to, i thought it would be slower.... think i need to adjust the idle a bit, thanks for the help matt....
Outstanding!
What axle ratio and tires size are you running?
wilber
Post by wilber »
35s, with 350 gears, 205 t case, clutch grabs, and feels like im gonna take off. still have to check some stuff out before i run it around a bit
I'm running 4.56's and 36's. My transfer case is also geared a little lower. Mine crawls awesome. It pretty much will idle over anything. My idle is set about 800 rpm.
My friend Steve put a FI 5.0L in his early bronco. His first few times out wheelin, he was killing it a lot. He said his carbed 302 had a little better low end.
He just recently replaced a part that allows him to adjust the idle. He bought it off ebay. I don't recall what part it is, I'll have to ask him.
My crawl ratio is 6.69 X 2.34 X 4.56 = 71.38:1
Yours 6.69 X 1.99 X 3.50 = 46.60
That's a pretty significant difference.
wilber
Post by wilber »
yea im plannin on the 203 doubler in the future..
if you chang your gearing to 5.36 or larger it will have the same crawl ratio :finger:
plowboy
Post by plowboy »
You gonna have that Beast at Attic on Nov. 13th? I'm hoping to make that one.
wilber
Post by wilber »
plowboy wrote:You gonna have that Beast at Attic on Nov. 13th? I'm hoping to make that one.
as long as i can
