90 BII A4LD
can someone please post a pic of their battery cables
as the title says - so I can see what all is connected to it? Is there supposed to be 2 smaller wires coming from one of the cables that leads to a sensor connection just behind the battery? Does the positive or negative cable go from the battery to another sensor connection underneath the vehicle on the side of the oil pan?
90 BII A4LD
90 BII A4LD
1990 Bronco II 4x4 2.9 auto
Re: can someone please post a pic of their battery cables
nevermind - found what I needed and completed the job
Previous owner used the wrong type negative battery cable unit. The correct one is seen below.
