battery not charging
Re: battery not charging
these will fry if you hook the jumper cables backwards also
jessezipper
that i didnt do, lol good to know tho, but seriously , can i get em at the dealer??
jessezipper
the blk/org wire coming from the alt to the starter silinoid had a black fusible link on it with 2 wires goin in and one coming out.. i tried a 14 and i think a 12 gauge and nothin happened. ( i got these at autozone, one was 1 wire goin in and a mountin ring on one side and the other was one wire in one wire out)
jessezipper
dude thats way more helpfull than my chiltons, judging by that i need the 16 gauge black one, thanx!!
nope, 14 GA green. fuse link C
jessezipper
mine was the black one the 16 gauge , the green ones fine, my black one fell apart
If you look at wiring diagram with ammeter the black 16 GA (fuse link W) runs the rear window washer, wiper and defrost. NEED TO CHECK POWER AT ALT!!!
got your PM, Glad to help. Even a broken clock is right twice a day.
I know its been a few years but I was wondering if the OP had ever fixed his charging problem. I have the same issue with my 89. It was mentioned to measure voltage at the alternator. Is this to be done with engine running, or not running? Key on or off?
Darn I used to be smart back then. Alt always has power, even with the key off.
