hey, ive got and 88 BII stock front end but i can get a d44 from late 70s bronco it has radius arms and coil setup how much work will this be to swap into my BII... ive heard 60s and early 70s are almost bolt in but what about from late 70s
anyone make this swap? i want a d44 just wondering what i would be gettin into with this axle
thanks for any help
SAS
Re: SAS
Late 70s might be full sized. If EB then it will fit. If from a FS then you will have to cut down the housing or you could try to fit it under the B2, but it will be very wide.
