http://broncoii.org/forum/index.php?PHP ... opic=926.0
fixing minor things
fixing minor things
hey all< have done a few maintanace jobs on the b2. power steering hose.shocks. front brakes, front spindel driver sidel.
(make sure to torque those nuts .Last work done didn't and it ate the washer, bearing and spindel.)found bad boot on the rear CV drive shaft and found another b2 site that shows how to convert to u-joint shaft for under $100.00.
looks preety nice seeing how the local jy didn't have a good one and the parts store wants $232.00.and the drive shaft company wants $325.00 to build one. fixed the passanger side elec window with out paying $10.00 for the plastic rollers. Trimed down wire nuts
more snow, no garage, no work this weekend. be safe. untill nex time.
Re: fixing minor things
used the tech talk.for the drive shaft and I now have a u-joint style rear drive shaft
. It took about 4 hours to do the whole job. price was 39.95 for the drive shaft parts. The whole thing was around $75.00 with the new joints . Now they are greaseable!!!
if you plan lifting your B2 you need that double cardan. its a waist cuttin it up like that
Not planning on useing the stock axle's if and when I lift it. wanting to do a sas, so new drive shafts will be in the works. It's an 1986 xlt.
you can use the xplorer front driveshaft and yoke and its a direct bolt in. as long as your B2 has the 145 tranny
xplorer yoke
i had to shorten this driveshaft cause it was going in a 88 B2
it's the auto over drive, would I have to change out the transfer case ?
