rotors.
tasteofkaos
rotors.
Post by tasteofkaos »
I know this is going to sound kinda stupid but when i went to order new rotors for my 1990 ford bronco 2 xlt 4x4. It came up with many options on which to use. Here is an example below.
(1) Application:
Built to 09/1989
With 3.73 front axle ratio
(2)Application:
With 3.45 or 4.10 ratio
Me coming from Hondas im not sure what they are taking about. I thought all rotors were the same besides being cross drilled and slotted.
Re: rotors.
is the front axel a D28 or a D35
oneway
Re: rotors.
Post by oneway »
i order 99% of everything for my BII from JCWhitney.com You can order stuff specifically for your truck and it is guaranteed to fit, unless you are trying to order aftermarket stuff....JCWhitney.com has some aftermarket options, but it's all mostly stock stuff, but either way...it's guaranteed to fit.
1990 Bronco II 4x4 2.9 auto
tasteofkaos
Re: rotors.
Since I don't have the door stick I'm not sure what axles I have. I may look into jc whitney once I get my pc up and running again.
Re: rotors.
look at the top ball joint, if there is a big nut on top its a 28
Re: rotors.
D35
D28
