Turn Signal
Turn Signal
When I use my right turn signal the Green arrow doesn't light up or blink and neither do the exterior front right turn signal or right rear tail light. You do still hear the blinker but it is faster and a little differant in sound. The left turn signal works fine
Thanks
Re: Turn Signal
check the W/LB (white with light blue tracer) off the mutifunction swt for the front and dash light and the O/LB (orange with light blue tracer) for the rear if the bulbs don't fix it. If the left works the flasher is ok. May be the mutifunction swt.
Re: Turn Signal
Now, sometimes it works and sometimes it doesnt. I wonder if there was moisture in a connection or if my switch is going out?
Re: Turn Signal
may be your Swt is going out. the next time they don't work, turn on and off your 4ways (hazards) a few times and see if it starts working. I got a new Mutifunction Swt from Napa a couple months ago cuase my Left turn didn't cancel. I felt dumb driving down the freeway with my turn signal on. So you can still get them.
