Lifting question
Lifting question
I'm thinking of doing a 4" suspension lift and a 2" body lift and was what all needs to be changed. Like brake lines, driveline, and shifter arms thanks guys
Re: Lifting question
Been a while since I lifted mine, but as I remember I had to move a few things. I only did a 4" suspension lift though. You can either get extended brake lines or you can re-route them for the 4-inch suspension lift, I don't remember if the body lift will change anything there. Try googling around, there's a lot of information out there.
The fuel filler tube, shifter linkage and brake lines ( from master cyl to frame ) are what you should look out for doing a body lift. I'm probably forgetting something but hope this helps.
-Jeff
'73 vw bug
'70 vw camper van
'98 jeep tj
2010 ranger
'56 international s110
'73 vw bug
'70 vw camper van
'98 jeep tj
2010 ranger
i have a 4" susp. and a 3" BL on mine an all i had to change were the gas filler neck and i got some steel braided brake lines.
