will a 5.0 bolt up to an a4ld transmissio
broncojeremy
Post by broncojeremy »
Re: will a 5.0 bolt up to an a4ld transmissio
no
broncojeremy
what transmission would i need and will i need a nother t case and drive shafts? axles
broncojeremy
i really like squeasing in realy tight spots and wider axles woult interfere
RClem
Post by RClem »
Kinda need more info.
What you trying to do?
What engine you working with?
What? What/ What?
To answer your question in a general sort of way. If you are trying to bolt a A4LD that came from a 5.0, to a 5.0, YES, it should bolt right up.
However, an A4LD from a 5.0 will not bolt up to any inline 4, or V6, or vice versa.
Ray
A4LD was never behind a 5.0
broncojeremy
i dont have anything to work with the motor i got needs a new crank which is like 500 so i figured id just get another motor but dont know what
