clicking tranny after clutch change
dckchapman
hello i recently replaced my clutch in 88 bronco11 2.9 motor every thing fine for several days then developed clicking sound in gear and even in netural but its really bad when in OD gear i had mechanic who replaced it diagnois the sound he claims its a bearing in tranny i cant afford another huge bill can someone tell me where to start? how do i rule out its not transfer case and if i pull it can i tell bad bearing by sloppy input shaft with side to side runout or end play he says its a common problem, junk yard says that year came with 2 trannys one with oil pan one without ive got the one without any ideas or similar problems experinced out there?
