Starter wont engage flywheel
Smash32
Post by Smash32 »
when i first bought the bonco II the starter worked fine but once that starter went bad and i replaced it it wont ingage the flywheel, the flywheel is fine no chips and ive replaced the solinoid, the sarter just wont work correctly this has been happening on and off for about 3 years any suggestions?
Re: Starter wont engage flywheel
try another one. ya shouls of brought it back when it first happened
Smash32
Post by Smash32 »
it is a new one this is like the 4th new starter this year
what year is your rig and what tranny??? is there a spacer inbetween the block and the bellhousing
Smash32
Post by Smash32 »
its an 84 with a 5 speed manuel no i dont think tgheres a spacer
well there ya go. it needs one
you need the aluminum piece
Smash32
Post by Smash32 »
serious thats all i need it workied fine before and i havent had that
well it sposta be there,all ford engines have them. its a shim for the starter..
Smash32
Post by Smash32 »
it didnt work it still wont engage the fly wheel and theres no chips or teeth missing on the flywheel either
well, i guess ya dont have to worry about it, your selling it :frown:
so you put the block plate it???
Standard Starter
Part No. 3188
Reman; INSTALLATION ALERT! This starter sensitive to high battery cable resistance; check cables to avoid mis-diagnosing a starting problem.; See Tech Tip # 120; Test Chart Page # S-1
Smash32 wrote:its an 84 with a 5 speed manuel no i dont think tgheres a spacer
whats the trans code on the door sticker
Smash32
Post by Smash32 »
u know what i have replaced that relay cable from the solinoid to the starter, right around the time i changed the starter when the problems started happening maybe that could be it and i dont want to sell it i just dont have a job right now and to get a job i kinda need a car that runs to be able to get me there u know
check the trans code
