PLEASE HELP!?!?!?!?!?!
Re: PLEASE HELP!?!?!?!?!?!
there are 3 ground wires hooked to the engine. The - cable bolts to the block,a ground strap from the back of the dr.side head to the fire wall and one in the wiring harness to the intake. and two from the -cable, 1 to the radiator support and 1 fuel pumps. heres the one on the intake
yeah i did and about got some gas in my eye lol.....
86 bronco II
2.9l v6 5speed
5.5" superlift with 33 12.5s super swampers
2.9l v6 5speed
yeah all the ground wires are still there
86 bronco II
2.9l v6 5speed
2.9l v6 5speed
try another computer. you know anyone with one you could try??
ta me,the injectors arent getting a signal to open or there completely clogged. you have spark,compression and fuel pressure but, the fuel isn't gettin into the cylinders
ok so i found a round plug that comes off the main harness and it has 4 wires going into it and the yellow wire and the black have power when the key is on here is 2 pictures of it let me know if you know where it goes
86 bronco II
2.9l v6 5speed
2.9l v6 5speed
mine goes the the harness for the injectors
when i unpluged it,wouldnt start
that one on mine is only a 3 prong and it has a connector in it
86 bronco II
2.9l v6 5speed
2.9l v6 5speed
im not sure
86 bronco II
2.9l v6 5speed
2.9l v6 5speed
86broncII wrote:that one on mine is only a 3 prong and it has a connector in it
mine has 3
its under the throttle cable bracket86broncII wrote:im not sure
yeah the one i found has 4 and i found it by the firewall on the passenger side and it was by the firewall and it has 3 powers and one ground with the key on but yeah it has 4 prongs and it was closer to the firewall so yeah i dont know
86 bronco II
2.9l v6 5speed
2.9l v6 5speed
and yeah i have the round thing under the throtle bracket
86 bronco II
2.9l v6 5speed
2.9l v6 5speed
ok, i have the same one, its hooked to the inner fender.it maybe be for some accy.i dont know. is the other plug(the one i posted) hooked up
can you take a picture of it for me and yeah the other one is plugged in
86 bronco II
2.9l v6 5speed
2.9l v6 5speed
