85 86 b2 parts
85 86 b2 parts
ok i have an 85 b2 with the carbed 2.8 with the manuel shifting transfer case that runs and drives well... it needs a front drive shaft and i have an 86 b2 2.9 efi and push button 4x4 can i put the front drive shaft directly into the 85? and i just want to tell you guys thanks yall have really helped me alot!
Re: 85 86 b2 parts
I don't think you will have any problems doing this swap just measure the driveshaft from u-joint to u-joint before ripping it apart.
'73 vw bug
'70 vw camper van
'98 jeep tj
2010 ranger
'56 international s110
'73 vw bug
'70 vw camper van
'98 jeep tj
2010 ranger
Re: 85 86 b2 parts
alrihgt guys i gave up on the broncos and bought another yota 12 inch lift and 37s soooo no more fords for a while
Re: 85 86 b2 parts
hey can i get the reverse light switch from the top of the transfer case from the 86?
i really need it. willin to pay some.
kolton
kolton
Shake and Bake
Re: 85 86 b2 parts
man i woulda gave it to you if i hadnt sold the bronco... you better hit up a junkyard
Re: 85 86 b2 parts
thats cool man but thanks anyway, ive pretty much been to every junkyard within 50 miles, no one has anything, and ford cant even get the part. but ima keep lookin
kolton
kolton
Shake and Bake
Re: 85 86 b2 parts
Hey Kolton.
Is that switch on the trans or transfer case?. If transfer case what type electric or manual?
I think I have an electric trans case around here if it is on that...
Let me know.
Let me know.
Re: 85 86 b2 parts
it comes out of the transfer case, right infront the shifter and to the right of the 4x4 shift. it has a green (or at least mine did) tail that comes out of the top that plugs into some of the wiring.
this is what it liiks like when its in the case. (the wires arent attached, its all shot and rotted)
this is the tail that comes out of the switch
it would be much appreciated, but if not its all good, i know ill find one sooner or later.
kolton
kolton
Shake and Bake
