How much lift do you run?
stevenf
Post by stevenf »
I know these BII's of ours are very top heavy. With stock rims(no extra backspaceing) what size lift would you recommend going? I was thinking of 32" tires but 33's with 1.5" fender trim MIGHT be the route I take.
RatBII
Re: How much lift do you run?
Post by RatBII »
i put a 3 inch suspension on mine and i got a 3 inch body to put on just waiting to buy rims and tires. im going to run 33-12.50-15 dick cepek crushers. just gonna take it slow around some turns.
Godzilla9992
Post by Godzilla9992 »
All i have done to my 1990 5-speed bronco II is 2" blocks in back and two of the biggest screw in spring spreaders in each front spring. I'm running 30x9.5 all terrains one the stock rims with only one problem, when the rear suspension bottomed out, the body cut the side of one of the tires, but i was doing about 30mph through some very rough trails in the woods. i'm very pleased with its speed and manuverability in 4-LO. Thick mud will stick it though. :frown:
stuck, look at my other posts for more pics
FORD....no other has so many acronyms.
WaPaul
Post by WaPaul »
4 inch lift but the new spring where holding the front at 6" so I built shackles and leveled the B2 so I am sitting about 6 inches. 31x10.5 tires.
I am getting ready to put a 2 inch body lift on, I am started on the V8 swap.
86broncII
Post by 86broncII »
wow by the looks of your b2 lift, my lift must be 7 or 8 inchs, i have more clearence with my 33s then you do with your 31s i will post pics soon i just got it lol :D
86 bronco II
2.9l v6 5speed
5.5" superlift with 33 12.5s super swampers
I used to run a 4 inch lift on both my bronco II with 33's and the one i had 44's with 4 suspension and 2 body lift!
86broncII
Post by 86broncII »
so here is a picture of my lifted bronc2 althought it isnt running right now but hopefully it soon will be i thinks it has around 6 inch suspension and maybe 2 or 3 body lift and its sittin on 33s
86 bronco II
2.9l v6 5speed
