I have actually just recently purchased my b2 and i have a couple f questions...
1. About 2 weeks after getting the truck, the radiator cracked. Well no big deal so i replaced it and ever since then, my temp gauge will not move...i have no idea why this is.
2. My left tail light wont work. The right side works and both the brake light and the turn signal work on both sides.
3. Last...when on the express way, the truck shakes vigurously between 55 and 65 MPH, but not at all at any other speeds. Once again, i have no clue why this is.
Any suggestions would be greatly appreciated. Thanks.
89 bronco 2 2.9 4x4 few questions
justbowl88
89 Bronco II 4x4 stock...for now
vabronconut
Re: 89 bronco 2 2.9 4x4 few questions
quote="justbowl88"]I have actually just recently purchased my b2 and i have a couple f questions...
Any suggestions would be greatly appreciated. Thanks.[/quote]
try a temp sensor for the gauge problem, also did you accidently move or knock off a wire on the engine?
did you try replacing the bulb, they are different bulbs for the different purposes.
for the shaking truck get the tires balanced
all three fixes for under $40
justbowl88
1. There isn't any wiring around the radiator that i saw, but i will definately take a second look.
2. It cant be the bulb because both the brake light and the turn signal use that same bulb, but they both work.
3. I'll give the balance a shot, but would it only shake between 55 and 65 if that was the problem? I'm only aking because im not sure...
Thanks for the reply...
1. It can be pretty easy to knock the wire off so that shouldn't be a problem.
2. Make sure you didn't put the bulb in backwards as it would opperate the bright filliment when it should be using the dim one.
3. I would say that it probably is an unbalanced tire if it only shakes at that speed. Same thing happend with my Jeep a few years back turns out I had a bunch of dry mud on the caked to the wheel throwing it off balance.
'89 Bronco II
'03 GMC Sierra Z71
'89 Bronco II
'03 GMC Sierra Z71
CarbedNotch
rim bent could b
justbowl88
fixed the tail light...the wires coming off the splitter for the trailor light were corroded. Any new suggestions for the other two would be appreciated.
Edit: This was a post about the tail lights......
virginiakid
The thermo sensor is very accessible, in case you haven't located it. As you look in at the engine, the sensor will be accessible from the topside about one-half way between the top of the water pump and the front end of the RH valve cover. It's got a little pop on plug with a single wire. check the connection there. If that's okay, then you probably need a new sensor. Unless your other gauges are also not working. Then it could be a fuse. I've got an 89 and had to install an after market temp gauge. the gauge cost $18 and the sensor about $8-10, as I recall. Very easy to replace/install.
Dane
He who trims himself to suit everyone will soon whittle himself away.
