My truck has a power steering fluid leak, brake fluid leak, and an oil leak. Does anyone know of any quick fixes for these or even suggestions on how to find the leaks?
O and also, my ac constantly runs even when i dont have the ac on. I have to disconnect the compressor to get this to stop. I have no idea why it does this. Any suggesetions would be appreciated.
89 b2 2.9efi 4x4 fluid leaks
justbowl88
89 Bronco II 4x4 stock...for now
Re: 89 b2 2.9efi 4x4 fluid leaks
Get a couple of cans of brake cleaner, do your brakes first since these are most important, spray in the aera that you think is leaking, get it clean! Hit your brakes lightly and take a look around, if it's wet, bingo! If not move to the next susipitious aera and repeat. Whatever the problem is FIX it, there is no suitable quick fix for brakes. Power steering could be a hose or pump. As for the oil leak clean eveything good and keep your eye on it. The a/c thing sounds like a switch issue, I live in Canada I just roll down the windows.
'73 vw bug
'70 vw camper van
'98 jeep tj
2010 ranger
'56 international s110
'73 vw bug
'70 vw camper van
'98 jeep tj
2010 ranger
