np435
Re: np435
There are several pictures of how I made mine here.
http://www.broncoii4x4.com/v8swap/302swap.htm
I used a compression fitting to adapt the stock plastic line to the landcruiser slave.
Re: np435
I have a '87 BII with a fuel injected 5.0 HO from a '93 Stang mated to a NP435 with a bell housing and flywheel from an '86 F150, and using a slave cylinder from an '84 BII 5 3/4 inch pushrod. Works great.
87 BII
5.0 HO
NP435
NP205
Dana 44 Front
Ford 9" Rear (thinking of swapping for a Dana 60 but need to research it first)
87 BII
5.0 HO
NP435
NP205
Dana 44 Front
87 BII
5.0 HO
NP435 4-Speed
NP205 Transfer Case
Dana44 w/ ARB
9" Ford w/ Detroit Locker
35" Pro-Comp MT's
5.0 HO
NP435 4-Speed
NP205 Transfer Case
Dana44 w/ ARB
35" Pro-Comp MT's
