Any info on a cheap lift for my bronco i want to clear 33s. will 4 in blocks in back and coil spring spacers in front work?? If so what do i use to keep the front tires aligned? Also will ford explorer suspension work on the bII?
any info will be greatly appreciated thxs!
budget lift for my bII
vabronconut
lift
3" body lift and some cut out flares are the cheapest, i have never used spring spacers, so i don't know about that.
cheap lift
Coil springs out of a ranger stx,with auto trans and air cond have a higher spring rate,thus raising the front. Getting yor rear springs re-arched with aleaf added will do the rear.Fender trimming still req'd.This worked for me until I was ready to go big.
'73 vw bug
'70 vw camper van
'98 jeep tj
2010 ranger
'56 international s110
'73 vw bug
'70 vw camper van
'98 jeep tj
2010 ranger
