help new 2 bronco and 4wheeling
shavdclean
ok im new to this game ive been in the custom lowering big rim bag job side of things forever and i jus recent acquired a 1985 bronco II that i my brother will be driving about 40 miles a day and i plan on takin it out to play on weekends and have quite a bit of questions ok well im wanting to put a 6" lift and a 2"or 3" body wut size rims tires could i run with that kinda lift? and with this question wut tire rim is preferred? also is a winch necsary and oversized offroad bumpers necsseary?if so were can i get em? ANY and ALL information will be greatfully apreciated! thnx!
well with 6" of suspension and 3 inch body you could probably run 36" tire or bigger but the odds of those axles holding up to that tire are slim to none. you do not have to do an extreme build to get these trucks to perform well
When I started my off roading i used explorer coils and leafs with 2" coil spacers and got about 2.5 inches of lift and with a little bit of trimming i was able to run 32x11.50 and it did well you could also upgrade axles with the D35 and 8.8 from an explorer these are stonger axles and wider also and the 8.8 usually comes with a factory limited slip rear end which perfoms much better than an open diff. just start small and learn the vehicle and work your way up to the big stuff and no a winch is not necessary if you wheel with others that have winches and by the way never wheel alone in my opinion 3 rigs minimum
regulate34
i have a 86
3 in body and 6 in suspen
i have 285/75/r16 bfg m/t and the are perfict i have an fullsize 8.8 in the rear with detroit locker
mine is extreme full hss bumbers front and rear
no glass and no back roof
i aint got a winch yet but am getting one 8000lbs will doo
and a roll cage is going in a little bit
and a ranger tailgate
lots done
but never finished
ps. make your won bumpers
and a seperate daily drive is the best way to go
never wheel alone
lots done
but never finished
never wheel alone
shavdclean
shavdclean
the way I did it it was a direct bolt in
the axle is direct bolt in period. but the drivesahft is a different story if you wanna run the tcase that you already have I think you have to shorten the front driveshaft. instead of shortening the shaft I swapped my b2 tcase out for the explorer tcase and then the front shaft from the explorer will work fine but then the rear shaft is an issue and what I did was buy the double cardan driveshaft from the rear of an 86 b2 i think and swapped out the flange that bolts to the 8.8
shavdclean
shavdclean
idnt think i go into the engine swap cuz it is gonna be a daily for my bro and fiance so and the bothe dont work so the got to be able to affford the gas and plus it wont be in the mud too often only wen i feel lik goin out the local swimmin hole! lol but i appreciate it all and how hard is ti to change the tcase?
shavdclean
