5.8L swap
5.8L swap
Well my 5.0 is getting tired and i found a great deal on ford bronco for 400 bucks with a 5.8L So far i have pulled everything out of the bronco, now i need to clean up the motor and pull all the smog stuff off. Next week i will be pulling out everything on my bronco II. I want to move everything forward about three inches or as far as i can so i can have a longer rear drive shaft. I will also be mocing the radiator to the back.
Bronco Ollie
pigmy pony
yeah i have been kinda lazy the last couple weeks. i have pulled everything out of the bronco, i tore down the whole wiring harnes and got it all mapped out so it should be easy to put back together. I decided not to move the motor forward becuase it would interfear with the front suspension. So this job is going to be alot easy then before. I ordered the duel oil sub pan today, and it should be in on the 12th. I will be changing the vavle cover gastkets in a couple days and painting the pan the intake and valve covers dark for blue when i change all those gastkets. Also doing the oil pump sense everything will be out so its a good time to do it.
well got some pics of the stuff i have been up to. I got the wiring harnse hopefully all ready. The good news i found out that this was a crate motor from ford. the bad when pulling the tranny some how one of the bolt holes for the tranny broke off and i was going to weld it back on but it some how dissapeared off the face of the earth. i got the new oil pump in and everything is ready for paint and then the reasimbily starts.
Well i finally got around to pulling out the 5.0. It was a pleasent 30 degreses outside while doing this too. I have been busy trying to buy a house so it has really taken alot longer to do this then i thought it would! I cant wait to get it up and running. I also donated the big bronco to the fire dept here in town and they cut it up for pratice!
- Attachments
- 1221071441a.jpg (24.45 KiB) Viewed 9466 times
- 1221071441.jpg (29.65 KiB) Viewed 9467 times
Its kinda in Got the motor mounts all welded up and bolted in. It was a real pain! I jacked up my finger and stripped out a bolt on the exuast manifold! It was a pretty crappy day but i got some work done which was nice. There was also a really nice message on the fly wheel from the owner before me.
