Alternator Ground
steiner_5000
Alternator Ground
This is a quick and maybe stupid question. How does the alternator get grounded. I just cant figure out why my alt wont charge so this is about the only thing i can think of.
isn't it case-grounded? the whole outside of the alternaator should be grounded to the mount. i had this happen to a buddy, took off the alt and found corrosion all over the mounts, cleaned em up with a wire brush and presto. alternatively, you can take a heavy guage wire and ground it to one of the bolts attaching the alt to the bracket.
hope this helps?
hope this helps?
Re: Alternator Ground
I HAD A FUSE BLOW NO MY '89 AND MY ALTERNATOR WOULD NOT CHARGE.
MAYBE?
MAYBE?
SGT. KYLE
