add pictures
gary6
add pictures
Post by gary6 »
ok im going to replace my drive shaft and put a 2 inch block suspenion lift on my 88fbII 4x4 and want o post pictures of of the step by step process of this. How and where on this site do i post them.
When you click reply or new topic at the bottom of the input page, you will see a section called Add an Attachment. Under the filename, there is a white box and and smaller grey box with browse... in it. Click that and it will point to your computer. Goto the folder where your pictures is stored on your computer and select the correct picture. Then click open and it will close input the file extension into the filename box. After you have attached the pic(s) then click submit. Its really simple. I hope I did not confuse you.
Shout out to one of us on here for help if you need it.
