How do you know if your bronco II is equipped with a tulip-style rear end.
What does it look like and what year models was it put in?
the black one is the double cardan shaft made by spicer. it is 31.75 inches, flange to flange. it is neither a ford part, nor is it used. (this is not the cheap route, but i have a three year warranty...and it's brand new.
the dirty dirty one is a tulip style, or cv driveshaft. it is almost identical in design and principle as the driveaxles on a front wheel drive car. ford did this disservice to us (correct me if i'm in need) in later production years - 88-90?
if you have neither, you could have this one.
this is called a single cardan d-shaft.
i believe that all three shafts went into the bII - depending on the year and transmission configuration. do you have an auto?
IIRC Jwillie on here used exploder flanges and DC joint and had the D-line shortened to eliminate the "tulip".  The "tulip"  is actually a constant velocity joint and junk for the application IMO, I used to machine the part for cv joints years ago and if they don't hold up on Honda front ends they won't hold up in 4L.
