351 winsor swap
351 winsor swap
will this fit i know a guy who has one for $100 in running condition and was wondering if it could be made to work he said same size block as 302 but I've heard otherwise elsewhere anyone know becuase if it will fit thats a great deal
What about emissons? I still would have to do that, doeas anyone have a 5.0 in washington? Are you able to pass or did someone get a special permit to have the 5.0? Other than that I'm good to go!
I believe it is against the law to modify your vehicle from the original spec that it came from the factory. (in the state of WA) A big emission no no. That being said, most of the time they will not inspect under the hood if you do pass. If you don't they will look and the harassment begins. I have not heard of anyone being sited for the mods but a guy I work with is being harassed cause he ran a big cam and carb and all of the other HP do dads which caused it not to pass. Never the less they told him to change it back before he can get tabs.
