Ultra budget lift kit.
decible01
Post by decible01 »
I'm new to the forum. I just got my Bronco II. Sole purpose for offroading. WHen I bought it it has a ghetto lift kit. Blocks in the back, and hockey pucks up front. Now I heard that there were some gm shackles that give you like a 2" lift in the rear. I also heard that explorer springs give about the same up front. How true is this. And does anyone know of any other cheap lift options?
Thanks in advance
Jeremy
texastud1983
Post by texastud1983 »
If your looking for cheap you can find lift shackles or a small cheese lifts on ebay. Type in ranger shackles or bronco II lifts.
But you get what you pay for. You might get the height but not the performance.
mikhail
Post by mikhail »
dont mean to thread jack but i have a 88 bronco II, and im looking for the same thing. i need a really cheap lift about 3-4".
do you know which gm springs are the ones that work? and would a ranger shackle lift work on a B2?
_________________
1988 Bronco II
Paul
Post by Paul »
http://www.broncoii.org/techpages/xsprings/index.html
you should c heck this link if your looking for some lift cheap, i know its not four inches but it is a start, and you will probably find that it will be an improvement regardless..... also you should be able to do this fairly cheap if you check the junkyards for these items.
Paul
Post by Paul »
http://www.roughcountry.com/ford_83-97_midsize.htm
or if you want to spend a little more than that check this link ...... it will accomodate 4 inches of lift to your Bronco II
