Gas Tank size?
jusserfinn
Gas Tank size?
I have an 86 Bronco II, and even though I know it's supposed to have a 23 gallon gas tank, when my gauge approaches empty, and I fill it, I never fill it more than 12 gallons. Could a previous owner possibly have put a smaller tank in, and if so, how can I tall? If it's the gauge, can anyone tell me what it would take to fix it? (I'm not mechanical, and YES, I am female)
jusserfinn
When my gas guage didn't work I replaced the whole assembly in the gas tank, (It's a combination fuelpump/gas guage sender unit).
The sender unit part which sends a signal to the guage on the dash, is made up of a float on a metal rod attached to a electrical devise I believe is called a slide-wire. As the level of gas in the tank goes down the float follows it and changes the position of the slidewire. That in turn alters the signal back to the guage on the dash.The guage reacts accordingly to reflect the lower gas level.
It's clear the set-up is poorly calibrated. Theres still plenty of gas when the thing registers empty and once the tank is filled up full, the gas guage pointer is way up past the full mark. If I had known this is how it was gonna work after I replacing the thing, I would have tried mayby bending the rod to have the float actually closer to the bottom of the tank when the guage was reading empty.
The drawback: the guage would stay stuck on full for an even longer period of time before it started to react to the level than it does now. ( Ever notice how it stays on full for a long time and once it starts to go down it does so seemingly faster than seems right.).
Oh well at least, as it works, it's predictable. I figure mine still has about 5-7 gallons in it when reaching empty.
dave
dave
greenmachine89
greenmachine89
Between my Rangers and my BII's the gauges seemed to work till about half a tank and then they would dive to the E mark. Sometimes it would crawl back up and go back down. The sending unit in the tank seems to get a flat spot. I would always set the trip meter and ran till about 228 miles. I never ran out of fuel and I would put in 12 to 14 gallons even when I was trail driving. I figure I was getting 15-16 mpg with 4:10's and 34's carbed 2.8's.
